Cutting metal out of door frame
Daytodog
Harrisonburg, Va
One thing about getting in and out of truck a lot is that darn metal at bottom of door frame always seems to get in the way of my feet when stepping in. Has anyone cut that metal out so that its flush with the floorboard. Just wanted to throw it out there for some feedback. Anybody think it will weaken it significantly or should I just brake out the plasma and go for it?
MtnSnow
14
NSL, UT
I think you could probably cut it down shorter like maybe up to half it's stock size, but I agree it's there for reinforcement so I personally wouldn't cut it completely out.
swbradley1
Modertator
1,686
Dayton, OH
Reinforcement aside, you could cut it out and put some other kind of bar across the bottom. If I have heavy boots on it is sometimes a pain to get my leg up in the truck.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
This has been brought up in the past. I think it was a fire station that cut theirs out, said the doors wouldn't stay closed after they cut it out. It wasn't right away, it was about a year later.
mattwspeed
Clrkesville GA
we have cut ours out of a crew cab we are building. We fully framed the top and added additional side supports to avoid cab flexing. These are for support since the tops are designed to be removed. You can do it but you must completely frame (box) in the top and add rear support so that the cab, top and windshield frame are all tied in together. Otherwise the cab will flex and your doors wont be able to shut.
