CV BOOT INSTALLATION
Inspector 1
73
Spring Texas
I replaced half shaft boots. I did not want to disassemble half shaft to install new cv joint boots as only the boots were torn. I replaced boots with new old stock. These boots are much thicker than aftermarket boots. I spent two hours trying to use the cone method in trying to install cv joint boot over the hub of the cv joint. No way the boot would stretch over cv hub. I purchased this tool from Dorman. It paid for itself in the 1st 5 minutes. Hooks up to air compressor, expands boot, fits over hub and there you go. A bit expensive at $200.00 but well worth it in saved time.
Inspector 1
73
Spring Texas
May I ask where you got the NOS boots? Are those 7 or 10k axles?
The Boots were purchased from SECO Parts :
HMMWV HUMVEE M998 M1025 HALF SHAFT BOOT KIT 5705605 NSN 2530-01-191-8741
( 163461050964 )
My HMMWV is a 1989. This axle I was assuming is a 10k. The large outer hub is round. The other 3 axles appear to be upgraded as they are different. They seem heavier. The outer hubs have flat spots on them. I was assuming that they were upgrade to a 12k shaft. I could be wrong. Maybe the shaft in pic is a 7K and other 3 are 10k. Any advice on that would be appreciated. I do know the boots were a bit large on the bigger end. I had to go to auto parts store and by the next smaller size band as the bands that came with the boots were to big. Smaller band compressed perfectly.
Ajax MD
1,414
Mayo, MD
@Inspector 1
I recently learned that there are "early" and "late" 10k axles. In order to upgrade to 12k, you need to replace the spur gear in the hubs and other things.
It seems doubtful that someone would upgrade 3 axles to 12k along with the spur gears and other work, but not the last one.
Based on that, I think you just have a mixture of 10k axles or maybe 10k and one 7k axle.
  • Like
Reactions: cwc
TOBASH
3,474
Brooklyn, NY
AWESOME device. Thanks for posting.
That being said, autozone sells H1 axles for about $113 apiece. Still, I want to buy that tool for my HMMWV and my other vehicles.
Thanks for posting!!!
T
Inspector 1
73
Spring Texas
@Inspector 1
After a bit of research is does appear that the half shaft that I replaced the boots on is in fact a 7K. The other 3 had been replaced and upgraded to the 10k half shaft. I'm grateful for the information received from you . Thanks again.
donquijote
36
Louisiana
T
Got a part# on those autozone cv's? I want to add them to my part cross reference excel spreadsheet. Search on autozone shows nothing for an H1 under CV. Thx
Sent from my SM-N950U using Tapatalk
TOBASH
3,474
Brooklyn, NY
Be careful. There are three part numbers.
The two front axles are not symmetric and require two different sizes. The rear axles are of equal length and require the same part number.
Read the fine print at autozone or you might buy the wrong axle for your requirements.
Best,
T
Retiredwarhorses
4,171
Brentwood, Calif
7k and 10k CV boots are not interchangeable
cwc
153
Sweeden, KY
I would not try to figure out 7 vs 10k but take measurements and get boots to match. I described this in the thread "CV boot on HMMWV" along with info on the the EMPI/NAPA selection. Since posting in that thread I have put on several more NAPA boots including one that was silicone. Seemed like a high quality product but was gray in color rather than black...
Sent from my E6910 using Tapatalk
Ajax MD
1,414
Mayo, MD
Because apparently I have too much money on my hands, I've purchased the Doorman CV boot spreader tool. It arrives today and I'll let you all know how it works out.
The tool has been out long enough that it sells on Amazon for $80 less than previous offerings with free shipping. If you want to keep American made axles on your truck but you don't have $800-$1000 to drop on new, US-made 10k axles, this is the way to go.
Face it, even if you do upgrade to new, 10k US-made axles, you're eventually going to tear a CV boot especially if you off-road. Are you going to just keep dropping $250-$300 on a new axle or are you going to get dirty and replace a $25 dollar boot?
Retiredwarhorses
4,171
Brentwood, Calif
replacing a boot on 10k shafts is much easier, the boots also last much much longer...
Ajax MD
1,414
Mayo, MD
Do the boots last longer because they have more pleats and flexibility? Or perhaps made from a better material? I can believe that.
I'm not sure I agree that they're easier to replace. There's nothing I found in the TM procedure that would indicate that.
In any case, the Doorman tool could make that discussion moot.
Retiredwarhorses
4,171
Brentwood, Calif
yes, material is one, and 7700’s have press fit bearing retainer as opposed to the large wire clip for the inner bearing cup for disassembly. Your doorman tool is for the soft boot, I only see bad things happening with the new style boot using the tool. Maybe it will work, But I really want to see how you take a 1.25in opening and stretch it to 4.5in without destroying the boot. I’ve replaced hundreds of boots in 30yrs as a mechanic, just did 8 boots an ITV last week.
Ajax MD
1,414
Mayo, MD
Yeah, it could be a fool's errand. We'll see. AMGen and Kascar (IIRC) were out of stock on the inner boot so I have one AMGen outer boot and one NAPA/EmpiUS inner boot. The style is the same but they do feel different.
The nice thing about the tool is that it's controllable. I'll pump it open slowly and if it looks like the boot isn't going to take it, I'll stop and tear the axle apart the hard way.
