Hello to all,
Today I was drain my D60 gear oil (looks nice no metal shavings in the magnet just something like grey sludge)!
I has about 5L so this also looks correct.
Altough I have two rookie question(s) for you :
I plan to have the front diff cover powdercoated but inside the magnet is glued to the cover...I think it must be removed prior to powdercoating ? Should I use regular paint instead ? Also I have read somewhere that you can install the diff cover w/o the gasket with just sealant ?
Thank you !
G.
Thank you !
G.
