- 1,156
- 4
- 0
- Santa Clarita, Ca
Hello , Dont know if this is the right area to post this being its about an 86 CJ but someone might have some experience with the problem I'm having. My transfer case wont shift into 2-Hi, if it does go into 2-Hi its for the front wheels only. When I put it into 4-Hi with the hubs locked the jeep doesnt move, kinda like one drive shaft is in hi and the other is in low range creating a major bind. I took off the shift rod covers on the rear of the t-case and the rods arent moving to the same positions equally. My questions is, is it possibly a major breakage inside the t-case or is my shifter more likely worn out and the problem could be fixed with a twin stick shifter? Im selling the jeep and this problem just happened after flat towing it about 200 miles. I stopped frequently to run the tranny and transfer case to sling the oil around like the manual said to do. Thanks in advance. Devin
