Dana 6453 question.
Crazy
SF, CA
Spicer 6453 question.
I have an unusual question. I have one of these transmissions coming. I would like to install this in my 1995 International 3800 school bus. It has the incredibly wonderful P.O.S. Allison AT545 transmission behind a DT408. I have been reading many posts on this site and the members appear to be much more mechanically inclined than many other sites. I know my bus is not a MV but the trans is from a MV. Both the engine and the transmission have a SAE #2 housing. How difficult would this project be? Any input would be appreciated.
A picture of my ride.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
Its a Spicer not Dana. That should help in some of your searches. I think it would be a plus for the bus.
NDT
6,233
Camp Wood/LC, TX
Simplest would be to find a International medium with the same engine and a manual trans and swap all components across including the bellhousing.
Crazy
SF, CA
Yes, but that would be the easy way...and sane way...I would have to change my user ID.
gimpyrobb
27,785
749
Cincy Ohio
When your looking for information, having good terminology aids in finding what your seeking. I was just trying to help him find what he was looking for.
NovacaineFix
San Diego, California
That makes perfect sense, especially when most everything you search for online is keyword based. I was just wondering if there was any difference, 'cause in my manual, it calls the tranny a Dana 6453, but it does have Spicer cast right on the side of it. I guess it like saying Chevy vs. GM.
Jeepsinker
402
Dry Creek, Louisiana
You'll need a flywheel from a standard transmission version of your engine, and a pressure plate and clutch disk from a 5 ton. I don't know if a flywheel from a 5 ton multifuel of NHC 250 will bolt directly to your engine, but I doubt it. You will have to get a flywheel made for your engine, and you'll likely have to drill and tap new holes to bolt the 5 ton pressure plate to it. You'll also have to figure out the pilot bushing. The bushing for a 5 ton may work, but likely you will have to have one machined to fit. Good luck, and let us know how it goes with your short bus. Any plans to paint it green?
Crazy
SF, CA
I haven't been here for a while. I have purchased a AT1545P that I think I will be using. As far as I can tell, it is the exact same size as the AT545 that I have but has a lock up converter. Thanks for the input received.
Crazy
SF, CA
Lockup is only going to drop you a couple hundred rpm vs direct drive non lockup. It is better, but still won't compare to the 3053a with the waterloo kit.
Yes, but I already have the AT1545. I would love an overdrive. There is only so much I can do and I will take that couple hundred rpm. Next step will be going from 9R22.5 tires to 11R22.5 tires. That should give me another couple hundred and last would be a rearend change from 4.78 to something like 4.44. All of these steps would be easier for me than trying to get a manual installed.
