4bogginchevys
- 1
- 0
- rathdrum idaho
I haven't found many previous threads for some reason, I would think that (IP) (rubber hoses) would have given more info......
My 1008 has a rubber line going from filter to IP pump...it's getting noticably worn and someone has double hose clamped it under the intake!!(cant be factory right?) Has anyone found this same problem? Is it a barbed nipple on the injection pump or did someone cut the metal line off? Has anyone found a good method for replacing this without pulling intake?
Does anyone know of a size/source for a metal line that will stub out next to intake so that I dont have this issue again when the next rubber line goes bad..... Thank you!!
