Dash light bulbs
rfischba1
Fort Meade MD
How hard is it to change the dash light bulbs in the cucv.s can you each the turn signal bulbs from under the dash to change the little sob's
319
Lieutenant
58
Michigan
You can reach some of these if you have small hands, but it's best to remove the cover and reach through the radio or volt meter opening for the right side. The left side you should be able to reach from the bottom.
I've installed a radio in mine and my hands are larger so it was difficult for me. I just took the instrument cluster out, cleaned everything (sand all over the place) including all of the connections and bulb holders, and replaced the bulbs so I won't have to do this again anytime soon.
pevrs114
32
Monroe, NC
Once you've got the dash off, it's not too much harder just to pull the whole instrument cluster. It's only 6 or 8 more screws. The hardest part for me was to unplug the speedo cable. Small hands and forearems makes it easier. Once you've got the cluster out, you can change all the bulbs at once. They take N194 bulbs. If you change the high beam indicator light, I used a blue bulb to make sure it stayed the correct color. Good luck!
