Data plate
Levi75
13
Spraggs pa
Hello, and thank you all for your help with my other questions!
I am finally getting back to looking up the TMs for my duece. I found 2 data plates but one has an NSN # that doesn't match any of the TMs, and the other one lists the TMs. If these are the correct data plates for this truck, are these what your data plates look like it, and what you are referring to when you say "data plate"?
One of the plates says -209- in the middle and ones previous listed on answers to my questions said -361-. All the other #s are the same. What is the difference between these TMs (209 & 361)?
Thank you again,
Levi
porkysplace
1,487
mid- michigan
Thank you again,
Levi
The 1st data plate is for a Hunter heater , probably added . The 2nd is correct the -209 is a older version of the TM's , Both sets can be found here : https://www.steelsoldiers.com/threads/tms-for-the-deuce.77607/
