Data port
bear76
The round data port under the dash, is it needed? The PO hacked all the wires under there and I'm still sorting everthing out. If it is not needed can I nix the harness for it on the other side of the firewall?
Thanks.
CUCVFAN
Gunner's Mate First Class
54
Jarrettsville, MD
It's only the diagnostic hookup. It was hacked off of my M1028A3 and never caused me a problem. I think you should be safe to lose it, harness and all.
ARMYMAN30YearsPlus
Parkville, MD
It was for the STE-ICE system sort of like a high powered OBD II hook up. The only worry I would have is if there was a sensor shorted out by wires being grounded or fryed by connecting with + 12 or + 24 volts. I think the 20 level manual goes into the use of the system and port hook up. This might be the best place to make a search of the issue.
bear76
It was hacked by the PO and I have not started it yet, just disconnected the harness under the hood. I will pull out all wires I can then tape off the rest till I get it on the road.
