jimm1009
- 71
- 48
- Louisville, KY
Hello fellow 2.5 ton owners.
I drove my M35A2 the other day with no known issues.
I walked out to fire it up for some light work about a week later and
it was electrically dead. Immediately I though that the batteries were dead as the heater
switch was left on in the low position.
I opened the battery tray up and found two bad terminals so I replaced them but no joy.
I roll started it and it runs fine but there is no electrical system. I checked all the battery cables for damage and corrosion.
It is as if the master switch is turned off and there are no lights, no electrical gages that are powered, etc. I drove it about
three miles to where I needed to park it and nothing changed during the drive.
I am looking for ideas on something like a dead relay, etc.
I will have to fix it now as it can not be pull started where it is parked in the storage facility.
Note: I purchased a new front harness due to some other issues with the original harness
being from 1970. Have not replaced it yet due to some very severe changes in my life and
housing conditions, etc. but I hope to do it soon.
A 2nd issue that has been mentioned; I have the old brake light switch that quite often leaks
and fails, etc. I want to retrofit my truck with the newer style air switch.
Thank you in advance.
