F-Twelve
- 1
- 1
- Meridian, ID
I was changing the headlights to LEDs then got distracted by family and left the ignition switch and light power on (all gauges were active). I left it for a few days without realizing it and now nothing will work. I've turned the light control off and on multiple times. And the ignition switch on and off multiple times and nothing. I put the batteries on a trickle charger and they're all good but still nothing. I have the TM and a multi-meter but I haven't had a chance to pull the dash. I was thinking the circuit breaker might be bad. Thoughts on that? And the light switch was replaced prior to my buying it (1970s M35A2) w/ a single pull switch w/ off, high, low positions only. It won't start and nothing will turn on. Any ideas? Or do I just need to pull the dash and start testing w/ the meter? Thanks in advance
