Decon stuff
19,750
Were these supposed to stay on the vehicle? Are they only mounting platforms or…?
And is anyone familiar with this antenna base?
Third picture - base with what looks like a ring of magnets - looks like it could be a non-factory mounting plate for a Convoy Light. Just guessing, but I wouldn't think (maybe I shouldn't?) that an antenna would be mounted that high and on a magnetic base.
I think the DeCon apparatus wasn't important enough to remove. I have two trucks with the same hardware hanging off the back - minus that "magnetic looking pole" on the right back of your truck.
INFChief
1,348
New York
I included a picture of the “mast” to that magnetic thingy picture. It indicates some sort of communication gizmo. There is a computer mount in the cab…?
19,750
Yes on one truck. Not the other and one has a group of 6 holes drilled in the right side of the cab where a BIG antenna would have been on my truck with the empty comm rack in the back behind the seat.
INFChief
1,348
New York
I’ve got the commo rack between the seats too. This had 2 antenna base mounts bolted to the upper rear cab corners. One base is with the truck - the other mount / base is gone.
simp5782
Feo, Fuerte y Formal
9,368
Mason, TN
It's for satellite tracking system
Ronmar
7,442
Port angeles wa
Yea, that was an old style antenna base for a data radio/terminal and tracking system. If you google the name on the antenna mount you can see the current version they manufacture. The old style used that mag base and an antenna array, the new style is a dome. Basically 1 or 2 rigs in a group would have these as C&C vehicles.
As mentioned that is the mounting place for the decon kit, basically a 5gal jerry can with cleaning fluid.
INFChief
1,348
New York
Its where you mount the decon stuff. Its not there. Bottom right pic is your abs module. You can take the antenna mag mount bracket off if you want.
Thanks; I hadn’t quite located the ABS module yet. Somewhere I read it was by the cab hydraulic manual pump. Was beginning to scratch my head.
