Deep Water Question
palskidoo
CT
I am new to the MV "addiction" and I have been reading everything I can for the past 2 weeks about m35's. This site is worth its weight in gold in that respect! I am amazed at the capabilities of the m35's and I'd like to buy a bobbed A2 soon. My question however involves deep water travel. I've seen videos of m35's in 6ft or more of water and they chug-along like a CHAMP! But how does the engine like the deep water travel? What about the radiator fan trying to spin underwater? is there any preparation to deep water travel or do you just hold your breathe and go?
hndrsonj
Senior Chief/Moderator
363
Cheyenne, WY
There are very few complete fording kits and the post fording maintenance is extensive.
palskidoo
CT
Yes Im a "newbee" and trying to gain a good footing on MV's before I purchase I own. I appreciate the warm welcome as opposed to other introductory conversations I've had on other sites.
Warthog
232
OKC, OK
Deep water travel should be reserved for emergencies.
The trucks where not designed to stay under water. Buy a submarine for that.
They where however designed to spend a short time getting wet
Just remember that steel and water usually result in rust.
The one issue with deep water fording that usually isn't addressed is the follow up maintenance that is required.
The wheel bearing on each axle must be taken apart and inspected. Water WILL find its way in.
Bob H
160
Yes you can find the videos of these things in deep water, too bad they don't show the 1/2 hour prep required before entering the water and 1/2 hr work after exiting the water.
or the 10 hrs of work & gallons of lube change to the axles, trans & t-case & bearings once you get it home. ( That's if it was driven in clean water ! )
Woodsplinter
Phoenix/AZ
Welcome Palskidoo!
I used to think driving my deuce in water would be cool, but after reading about the "after" maintenance there's no way except in an emergency.
Somewhere, I saw a video of a soldier driving a deuce underwater while wearing scuba gear- haven't been able to find it lately.
palskidoo
CT
Thanks a lot to all who replied. Unfortunately like with most everything kool or fun it seems the consequences and maintenance of the act out weighs the fun. Once i find my deuce Im going to avoid deep water unless an emergency calls for it.
