Delco - Remey 27 si Alternator Question
Payback
Tabernacle NJ
I got a gen2 light on full time and the pass. side battery is not charging. I purchased a rebuild kit for the 27 si and did the re-build over the weekend. Re-installed the alternator and still won't charge the battery. In doing the repair, I didn't get this part in the kit, there is also one similar on the rear of the alternator that attaches with the black wire to the post. I do not know what they are or what they do so I am asking here.... And could they be a reason for the re-build not working?? I have been over most of the truck and everything wiring wise looks in great shape, no one has done any hackery to what I see.
What should I be looking at as a cause of the lack of charging, if the alternator re-build was done correctly?
Payback
Tabernacle NJ
Does the charge light come on key on engine off?
All lights on the dash light up with the key on prior to starting. Once started, only the gen 2 light stays on. Now, I am assuming that if the light is on, the charging system is not working right. I have not tested it with a meter to confirm but will tomorrow. The mil. spec. voltmeter in the truck also works and I did not notice a charge while running.
The condensers, how can I find out more about them, I would want to replace those as well? All replaceable parts should be replaced when doing a re-build. Thanks in Advance...
Tow4
640
Orlando, FL
It's a capacitor for radio noise suppression. It doesn't affect alternator function.
Take the alternator and get it tested or do the test sticky at the top of the CUCV forum.
