Description from MS number
cranetruck
75
Meadows of Dan, Virginia
Hi,
I have a damaged castle nut that needs to be replaced and cannot find a description for it other than a general one, "Nut slotted" or something to that effect.
The Number is MS35692-77 and is for the tierod end shown in the image below.
It appears to be a metric 24 mm. The tractor place here in Meadows of Dan had no metrics that size and a 1-14 inch standard thread does not fit.
Is there a look-up table available to find a detailed description based on the MS#?
TIA
red devils dude
Ft Campbell
bjorn not that I know of, I'm always trying to find specs on the internet with little if any luck but some times
a "google" search will try up a manufacturer that can give a civvy cross hope this helps.
TacticalTruck
Va Piedmont
I'm working on a lead for MS info but I would figure you'd have a set of calipers and some thread gages to measure it and then buy from McMaster-Carr or similar. The second site I listed has specs available for a fee.
Jeff
surpdlr
PA
cranetruck said:
Hi,
TIA
Does this help:
THREAD CLASS 2B
THREAD DIRECTION RIGHT-HAND
NUT STYLE A17 SLOTTED, HEXAGON
NUT HEIGHT 0.831 INCHES MINIMUM AND 0.887 INCHES MAXIMUM
WIDTH ACROSS FLATS 1.450 INCHES MINIMUM AND 1.500 INCHES MAXIMUM
TEMP RATING NOT RATED
THREAD SERIES UNF
THREAD QUANTITY PER INCH 12
HARDNESS RATING 69.0 ROCKWELL B MINIMUM AND 32.0 ROCKWELL C MAXIMUM
NOMINAL THREAD SIZE 1.000 INCHES
BEARING SURFACE TYPE CHAMFERED OR WASHER FACED
MATERIAL STEEL OVERALL
SURFACE TREATMENT CADMIUM OVERALL AND CHROMATE
SURFACE TREATMENT DOCUMENT AND CLASSIFICATION QQ-P-416,TY 2,CL 3 FED SPEC SINGLE TREATMENT RESPONSE OVERALL
NONDEFINITIVE SPEC/STD DATA 4 TYPE AND 16 STYLE AND B GRADE
Jeff
emmado22
143
Mid Hudson Valley NY
Here ya go...
User ID: castle nut
Characteristics Data Response for NSN 5310-00-070-1902
Item Name: NUT,PLAIN,SLOTTED,HEXAGON
MRC Requirement Statement Clear Text Reply
NAME ITEM NAME NUT,PLAIN,SLOTTED,HEXAGON
AAJD THREAD CLASS 2B
AAJF THREAD DIRECTION RIGHT-HAND
ACTA NUT STYLE A17 SLOTTED, HEXAGON
ADEA NUT HEIGHT 0.831 INCHES MINIMUM AND
ASDB WIDTH ACROSS FLATS 1.450 INCHES MINIMUM AND
AZKQ TEMP RATING NOT RATED
BZRR THREAD SERIES UNF
CMLP THREAD QUANTITY PER INCH 12
CQFM HARDNESS RATING 69.0 ROCKWELL B MINIMUM AND
CQJX NOMINAL THREAD SIZE 1.000 INCHES
CRTM BEARING SURFACE TYPE CHAMFERED OR WASHER FACED
MATT MATERIAL STEEL OVERALL
SFTT SURFACE TREATMENT CADMIUM OVERALL AND CHROMATE
STDC SURFACE TREATMENT DOCUMENT QQ-P-416,TY 2,CL 3 FED SPEC
AND CLASSIFICATION SINGLE TREATMENT RESPONSE
OVERALL
ZZZT NONDEFINITIVE SPEC/STD DATA 4 TYPE AND 16 STYLE AND B
GRADE
