Deuce alternator showing overcharging
meindl
germfask, mi.
In my Deuce, the alternator showing and sounds different when the gauge shows its overcharging. This seems to only happen when I'm wheeling down the road at 55 m.p.h. give or take a m.p.h. I can hear something whining away under the hood, then check my gauges and I see the alternator gauge in the red. I can shut of the accs. switch for 10 seconds or so the whine goes away imediately, and turn it back on and all seems fine. This has happend 3x when I went to to town and back the other day. Any ideas? It seems fine at slower speeds.
Thanks Meindl
Wildchild467
56
Milford / Michigan
i think the sound of the whine is the typical sound alternators make when charging. something is making it go to fill charge. i would guess it is the voltage regulator is messing up. i know someplaces online you can get new ones, but it requires soldering the old one off and the new one on.
Warthog
231
OKC, OK
I also agree that the voltage regulator may be on the fritz.
Before doing anything loadtest your batteries toi make sure you don't have a bad cell in one of them.
PS. Moved the thread to the Deuce forum for better coverage.
