Deuce Belt Interchange
Racky
Monmouth Junction NJ
Hi All and happy new year. I took the #s off the belts on my deuce and went to Bep Poys. Well the counter person was you know, well do I need to say anymore. The dayco # is 43-9018. Does anybody know the new dayco #
Thanks in advance
Racky:?:
HeadWizard
Chantilly, VA
they're all on the old site in the parts cross reference section. Probably somewhere on here also - but I haven't found them :?:
Probably has something to do with a Wiki ;-)
11Echo
92
CT W. R.
The NAPA #'s are
25-9510 Compressor and I paid $10.18
25-9470 x 2 and I paid $14.98 each
They had them in stock and I carried them out the door today along with the lower radiator hose for $16.20.
  • Like
Reactions: 052
wsucougarx
65
Washington State
buy your belts through OD Iron. He has the NAPA ones. I took the model #'s down to our local NAPA store for the exact same belts. OD Iron sells one of them for $6-7 and NAPA wanted $22 for it. I was like no way
  • Like
Reactions: 052
jatonka
57
Ephratah, New York
I find it better to use a 46 1/2" generator belt instead of the 47" belt you are referring to. When they age some, the 47 is able to stretch and about hit the fuel filter base when tite. Also, no NAPA hose is as good as the military lower hose, from www.adirondackdodgeparts.com or Saturn Surplus. From experience. JT out
052
Elko, NV
Jatonka,
Do you have a part number for the slightly shorter belt or are you getting them through Adirondack or Saturn?
Thanks 052
