Deuce Blown Michelin Fun.
olewhiskey
Winder Ga
Blew a tire about 48mph goin downhill over a concrete bridge. Clipped the abutment,fishtailed,clipped the guardrail and went back up a 30 degree embankment were the trailer did a slow rollover.
Rustygears
Ramona, CA
Wow!
Another rotten X on a steering axle. These tires are a pos and you can't find them anywhere. I have the same tire position with a shredded sidewall. Thank God I saw it and took the truck out of service before I too had the same brown seat event! What are the date codes on your tires? Mine are all 1995 - too old!
1,178
In the future, please do not post multiple threads on the same subject or continuing discussions in other posts you made. We call this cross posting(against the rules, and hard to follow). Information needed to understand this thread is now spread around in the other threads you posted. Thank you
Heavysteven
10
Hickory Flat Ga
:eek:It's totaled for sure, I'll take it off your hands for free...
Just joking but looks like its going to take some work to get it fixed. This has got to b the second thread i have read about an A3 blowing a tire.
shootiniron
13
Escalante,Utah
I've got a left front that was near flat for who knows how long and had a visible crack on the inside sidewall,however cant see it now that its aired up.I guess I had better change it before I make the journey home.What a PITA!
treeguy
Fort One Bay - Cape Cod, MA
I've got the same Michilins and I think they are older that yours. They've got the side wall cracking and everything, I think I need to put a change of underwear in the glove box just in case. Sorry that had to happen, when I saw that I thought OH .... what happened?
olewhiskey
Winder Ga
I have a nice pic somewhere of it parked up on the bank with the trailer flipped . My plan after repairing all the damage is to quickly dump the Michelin's, I will NEVER trust them over 5mph . I have rounded up all the parts I am aware of that are damaged. the only thing i don't have is the rear axles weepy seal and check the front passenger hub for wreck damage.
olewhiskey
Winder Ga
Copy that.
treeguy
What tire options do you see out there? I've tried to find similar aggresive tires in my 11/20 size and there isn't crap for choices. I noticed that yours look larger so you may have an easier search. Also the only available that aren't a million dollars are used tires, so now we're back to what type of life have they have. Good luck!
