Deuce bobbed w/ rear axle ?
tamangel
19
Nor Cal Coast
Can any of you guys with 'photo shop' show me a bobbed deuce pic with the rear/rear axle left on instead of the front/rear axle that most folks have? Curious as to proportions with 12' bed..
Mike
73m819
319
gainesville, ga.
do you mean the rear axle in the rear axle place only a long wheel base 4x4
tamangel
19
Nor Cal Coast
I think thats it.. looking at your wrecker avatar, remove middle axle, leaving only front axle and farthest rear axle...wanted to see what a 2 axle deuce looked like w/ stock 12' bed..
Mike
clear as mud I guess, sorry...
73m819
319
gainesville, ga.
RE: Err oopsie
looks like something that you would have seen out of the rusky lend-lease program
Jake0147
Panton, VT
RE: Err oopsie
I don't think it'd drop the payload any more than flipping the hubs and using single rear wheels, which apparently had very little impact on the payload. If it had a freightliner cab that's how you'd expect to find the wheels for a truck in this weight class.
Now, if you get into moving the single axle fore or aft from the centerline of the two original axles, then you're going to find big effects on the payload, but it won't be tire related, it'll be structural.
Jake0147
Panton, VT
RE: Err oopsie
I'll agree. I could see just as much practical reasoning for doing this as for doing the bobs (albeit a quite different use), but I don't think it's very likely to happen to mine.
Jake0147
Panton, VT
Absolutely, a chain is only as strong as it's weakest link, but in this instance you're starting with a lot more in tires than you have in GVW. You'll loose a touch, but you're talking about perhaps ten or fifteen percent of the highway capacity.
