Deuce brake problem
cbvet
20
Northwest (Knox) Indiana
On our 1952 M35-
Over the last 100 or so miles, all short trips, the brake pedal has been getting a little higher. It now has about 1/4" travel before brakes lock up.
Any suggestions?
It looks like I may have a leaking rear wheel cylinder, which I can rebuild, but I can't imagine what that would have to do with this problem.
I'll check back in a little later for your advice.
Thanks,
Eric
CBVET
Westech
CPL
6,104
208
cow farts, Wisconsin
if you have any fluid IE grease, brake fluid, axle lube.. the brakes will lock right up with drum brakes. Trust me I know all about the deuce brakes and there short comings. make sure to clean everything very well and fix the leaks
Westech
CPL
6,104
208
its grabing.. as soon as there any pressure on the shoe to drum it "sticks". before when it was all clean the shoe would be contacting the drum but it would take more pressuer to start to stop.. more pressure = more pedal travel. the shoes are still contacting at the same pedal travel but before it was taking more pressure to start stopping. grease or any fluid will rase the fibers or can even swell the shoe (making it larger) so with the raised fibers it will "dig" in to the drum.
Boatcarpenter
17
Marlborough, NH
Don't know if you have ever changed your flexible brake lines, but if they have not been done for many years, you may have a deterioration of the innermost layer that is not allowing the fluid to return towards the MC after you apply the brakes.
jwaller
19
Columbia, SC
I just changed all my flex lines and added speed bleeders. it was about a 3hr job start to finish. not bad really for some added piece of mine with a single circuit system.
cbvet
20
Westech had it right!
Pulled the wheels/drum. Everything wet with 90w, brake return spring disintegrated, wheel cylinder boots gone, pistons frozen. Shoes so swollen & saturated you could scrape lining off with a screwdriver.
I've worked on vehicles for 45 years, but have never seen shoes crumble like that.
Thanks again, I'll be ordering parts Monday.
Eric
CBVET
