Deuce brakes LOCKED UP
dm22630
42
Front Royal, VA 22630
I was getting my deuce ready today for the trip tomorrow up to MD for the Steelsoldiers breakfast. Maddawg308 was going to be at my house at 7am & I wanted to make sure everything was good to go today, so I could hop in & go tomorrow.
WELL.....
I worked on it doing misc things (checking lights, airing up tires, checking fluids), then I drove around my front field. When I was about to leave to go get diesel, I had to turn around (3 point turn) and when I stepped on the brake it felt like I slammed on them. The truck stopped instantly & the brake petal was all the way up & would not go down. I got out, looked underneath, got back in & tried to brake. This time it went down 1/4 inch. The truck would not move. I let it sit 5 minutes & got in & backed into its parking spot.....touched the brakes, they locked up & the petal is all the way up again.
Needless to say, my plans tomorrow are now shot. No breakfast for me. I was looking forward to meeting the Maryland SS members too.....I guess that will have to wait until the next meet now.
Is my master cylinder screwed up?
If not, what else?
Thanks!
joec
Vincentown,NJ
Sounds like air pac..open the emergency service and supply on the back of the truck if the pedal isn't rock hard and the truck moves that is your problem..! Happened to me a couple of times . And you can move the truck and stop it. Just will have manual brakes so drive easy testing.
My M543A2 did it once and i drove it 20 miles with the air bleeding off on the service and emergency suppply.
54reo
49
Chester IL
While the air pack could cause this, and I would try draining the air first,....
My truck locked the brakes once. It too had a pedal with no free play at all. My problem was a loose jamb nut on the master cylinder push rod that had allowed the push rod to lengthen over time. In effect, the brakes were never fully releasing.
If dumping the air doesn't help, take a look at the push rod and be sure it has 1/2" free play. (at the pedal)
bigmike
355
Dixon CA.
There is a ton of info regarding brakes locking up. Here is my problem and solution. I also have had the brakes lock up. It took a couple of pumps but the pedal was all the way up and rock hard...brakes locked up.
I bled a back wheel cylinder and fluid shot out and the brakes let go.
Long story short, I found the small return hole in the M.C. was clogged and wouldn't let the fluid return to the resevoir. After replacing the M.C. problem solved...I even saved the old M.C. by cleaning out the return hole.
My airpack was fine.
RangerDave
Bar Harbor, ME
I have just started experiencing some brake issues when my truck is loaded and am trying to stop (it is also very cold outside.... 25 to -15 F).
As I am downshifting and preparing to stop, I step on the brake and it feels normal.
I step on the brake again and it gets a little harder (I'm assuming its the air assist helping to put more pressure on the brakes).
by the third or fourth time I step on the brake it has only an inch or so of play and very little stopping power that I can sense..... kinda the opposite of the brakes locking up you guys are talking about, but I figure connected somehow...
