- 307
- 2
- 18
- York, PA
I've been reading, searching and looking up TM's. However, I still have a question or two.
I have to recover a Deuce with no brakes. Pedal goes to the floor. I have good air so it's not that. I need to investigate where the leak may be. Any suggestions?
I suppose the first thing I need to do is refill the master cylinder. Looking at the TM, do I remove the nut/plate that is about 1" in diameter on top under the hatch? Or do I somehow use the nipple on the top of the plate? After that, what fluid do I use and assuming I'm completely out, how much do I need?
Any help is greatly appreciated. I'd like to drive home as opposed to towing. Unless someone has a tow bar in southcentral PA that I can rent/borrow.
Thanks guys.
J.
Thanks guys.
J.
