gimpyrobb
dumpsterlandingfromorbit!
- 27,786
- 755
- 113
- Cincy Ohio
So, I have been having trouble with my airpack recently and since I have a new one in the parts bin, it was time to swap it out. In getting ready to swap it, I drained all the brake fluid I could. While doing that I noticed the master cyl was leaking ALOT of fluid from places it shouldn't. SO it got a rebuild too. In all the reading, and all the conversations I have had with other MV guys, I don't remember hearing about how much of a pain in the azz it is to get the master cyl out! For anyone that is reading this, I will tell you that I ended up getting 3 of the bolts out no problem. The upper "driver's side" one was not fun. I finally got to it from the back of the truck going forwar through the cross member hole, with a universal adapter. Wow, glad thats over! smooth sailing from here on. WRONG! The master cyl is wedged in between its mount and that darn cross member. I ended up taking a side and bottom plug off the rear-end of the master in order to get it out. Wow. Well, it is all back together, now all I need to do is bleed the system and test it out. Good luck to anyone that has to do this.
