deuce frame attachment
1,806
Yeah, you shoulda told me a few weeks before the GA rally. I still had the L shaped plates that bolted to the frame to support the factor headache rack. They went to the chipper during my scrapping binge. Speaking of which, another binge is coming on.
ARMYMAN30YearsPlus
Parkville, MD
The way we set up drag plates on my Son's Jeep was to make two 1/2 CRS very big plates and use grade 8 bolts to tie them to each side of the frame pinching the frame between them.
All holes were above and below the frame and we put additional heavy pipe in the frame to also be pinched between these two plates all of the welding was done to the plates and the drag plates are thus attached. I wish I was home I would shoot you a picture of this but it worked very well with no welding or drilling on the frame
wreckerman893
Possum Connoisseur
15,620
2,022
It is not a good idea to burn holes or weld to a frame rail.
It buggers the temper of the metal.
If you have to have a hole use a BF drill, preferably a slow one with a new, sharp bit.
It will take a while but can save a lot of grief over frame failure.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
They have very reasonable prices at Peterbuilt of Cincinnati for big U bolts and all kinds of stuff. Maybe look at a shop near you.
WillWagner
2,552
Monrovia, Ca.
You can drill the frame rails, just don't drill, cut or weld on the flanges. Side = OK, top or bottom = not OK.
Jones
Sacramento, California
Like Kenny and David say; a plate on the opposite side of the bracket will reinforce any bolt hole you drill through the frame. In the case of a single hole, large diameter washers under the head and nut are best. If you're setting up a pattern of holes then a plate with the same pattern works as well. If you can afford one, or know someone who has one, a magnetic base drill is the only way to go for BIG holes. I did the baby HEMTT's cab and front skid plate mounts and the spring perch mounts with one set up for roto bits and it sure made life worth living again; especially for holes on the horizontal or up from the underside.
TIP: If backing up a bolt and nut with flat washers, use self-locking nuts. If you use lock washers, you're only locking the nut or bolt to the washer, not the frame. Lock washers are fine if you're using a backing plate with several holes as it won't spin on you like a washer will.
acetomatoco
Most of the commercial headache racks I have seen are U bolted around the frame section with no welding or cutting of the frames needed...check out some at the local truckstops...Petes, Navis, Western Stars etc.
BFR
Rocket Surgeon
2,331
North Georgia
Re: RE: deuce frame attachment
I had resigned myself to not having a rack as it is temporary, but a good bit of free steel just found it's way to me.
spicergear
26
Millerstown, PA
RE: Re: RE: deuce frame attachment
I had to drill 24, 5/8" holes thru my frame when I mounted the M977 crane and outriggers. I took two drill sizes before I got to the 5/8" drill bit. That way I only needed to use a BF drill for the last size hole. I only broke one drill bit when the BF snagged and popped off a 5/8" bit. You will not enjoy the time you spend doing that. ...in any way. ...really. ...I wouldn't kid you about that.
Blythewoodjoe
56
Blythewood, SC
What's a BF drill? I have drilled lots of frame but never used anything but a standard 1/2" drill motor and my big old butt.
rmgill
14
Decatur, Ga
I didn't have too much trouble drilling the frame for my second fuel tank's mounting arms. 8 bolt holes with a titanium coated bit cut pretty quick, even with a battery powered drill. Just make sure that what is behind isn't going to be cut by the drill bit when it gets through (electrical wires being the most delicate).
ARMYMAN30YearsPlus
Parkville, MD
I have a BF drill, it is a #3 MT with a 1 inch pipe handle opposite the long switch handle which has a paddle switch. It is older than dirt, I watched as my Father and Grandfather used it to drill holes in prestressed concrete beams on our farm. All I know is it sounds like a duece when running (the whine) and if it catches a bid on a spur it will turn me around if I can hold on. The thing only spins at about 150 RPM but it has never ever slowed down drilling through anything. When I get home I will post a picture of it but that won't be till 2008
gimpyrobb
27,785
749
Cincy Ohio
David, I have a drill just like that! It has some kind of gear reduction and will rip your hands off if you catch a snag in something. The only time mine slows down is when I let go of the trigger. Can't tell you how many times I have had to put a new cord on that sucker.
mangus580
282
Western NY
I had a drill like that clear me right off the back corner of the M116A1..... was drilling through the deck when it caught. The spinning drill made my hand lock the trigger on its way around, tossed me from the trailer and spun until it yanked the cord out. I had bruises to prove it for a month.
Armada
Buick City, MI
I fractured my wrist on one of those once. I was boring a hole through a sill plate and it caught. I was off balance to begin with and it put me on my face and wrapped my hand around it. Man did that hurt.
