Have you ever finished this move ? And if so how it went ? I'm interested to move my 109 this fall from MD to MT. Cheers !
I made the trek, with only some oil leak issues that were resolved about 1/2 way through the trip. Details are in above posts. Good luck with your trip, and bring a buddy/helper along. PM me when you get closer to your voyage date, and I'll send you my contact info in case you run into any trouble within MT state lines... I'm typically in Central MT, but often in Western MT too.
Since getting my M109 home, it's been at work every day with me since April. Although the truck doesn't move much, the 109 box has become my job-site office and is working great. I've been too busy to do much work to it, but I plan to do some more refurbishing this fall when work slows down.
On the to-do list:
Remove CTIS; I need to keep things simple
replace/re-seal wheel rings
new tachometer (recently opened up the dash panel, and found why mine isn't working: it had been wrenched upon with some pliers, and looks pretty shredded)
replace all wood in window frames (on 109 box)
replace screens in said windows
diagnose/fix/replace M109 electrical. I may re-wire the whole thing and install RV style 30-amp cord to the outside
I'm working in a pretty remote area of Montana, and there is limited phone service and no internet, but I will try to get more photos uploaded.
A couple quick and easy mods I did since my last post:
I bought a motion-sensory LED light (battery powered) and installed on the shifter casing which faces the drivers feet (or an intruders eyes). I think it was under $10 at Walmart, and it came with a sleeve so you can remove it and use as a flashlight.
Also at Walmart, I found a steel box in the sporting goods area. It's a locking pistol case made by Winchester (not a safe). I think it was around $20-30. I bolted it upright on the rear of the cab so that the single swinging door opens towards the front of the cab. I now have a locking compartment. I left a gap under it, so there is just enough room for my power inverter to sit on the floor.
I found a new (still in wrapper) Titan 3500 diesel Generator for a good deal on craigslist, and it's ready to go... as soon as i can get the electrical system in the 109 working.
I have a new shore power cord for the M109 box if you (or anyone else) is interested... I don't think I'm going to utilize it.
$200 OBO I'll probably put it up in the classifieds as soon as i am eligible (need some more posts I think).
