Deuce horn
EdMontana
TN
This is what I have (first PIC), is missing the center only.
I got a kit on eBay (second PIC) that has nothing to do with what I have, is there another model? will I be able to install it and if yes, anybody have any instructions? I cannot see anywhere where the lead electrical cable should go....
Thanks!
jatonka
87
Ephratah, New York
Hi Ed, The first picture is of the updated horn button kit to replace the one in the second picture. You are missing the button assembly assembly from pic #1. The original button kit in pic #2 looks complete and NEW. You will do well with it for several years, then you will want to disassemble and clean tarnish off the contact area. Hoping you have assembly instructions with that new kit. The conical split plug goes up the end of the steering gear box where the wire comes through to hook to the harness. when you feed new wire through the steering column, go from bottom to top. VERY hard to come down through. John Tennis
