rizzo
- 8
- 38
- Port Huron, MI
can you flip the front hubs in? the same way you flip the back out?
will a hub off the front fit on the back?
I agree. two of the trucks we are putting the 46's on is a yard truck. one is a M35 the other is a GMC with dual tires. M??TXSG_19_commo said:I think that's a bad idea but it's your truck. M35 brakes are finicky enough and when a vehicle stops, a large load is carried by the front brakes. Myabe ok for putting around the farm, but I wouldn't chance it on the road at speed.
the 46's won't fit in the front with a stock deuce rim. they will hit the drag link.jasonjc said:Flipping the rear hubs put them inline with the fronts as is no front flipping needed.
Trango said:You couldn't pay me enough to ride in a deuce without front brakes.
That said, why not just build custom rims? It's easy enough. Heck, I'll sell you stock 2 deuce centers for $40+shipping when I pull them off my buggy.![]()
you must be the type of guy that puts his seat belt on to move the car to the other side of the driveway. or you live in the mountainsrizzo said:just trying to get around making custom wheels up front.....these are yard trucks. the one is only used at mud bogs for recovery
the 46 inch tires have a 14 inch wide tread pattern. if I put them on the front stock rim they will rub on the drag link. so that means they have to be moved away from the frame. the only way to move the tire away from the frame is with a M135 rim or custom rims or dish out the stock rims.houdel said:Guess I don't fully understand what rizzo has in mind.
If I had easy access to good used 46" Michelins I would consider building custom wheels starting from cheap M35 wheels. I guess every machine shop/good welder could do either of the following options without charging a fortune. For the 15" wide tires I would prefer 12" wide rims and keep the std. 10.5" backspace, with the rear hubs flipped. The stock 7.5" rims are far to narrow for these tires.rizzo said:2--Custom rims are expensive and I am trying to avoid that...
am I missing anything? does anyone see any other options..
