Deuce in tank pump
rlp094
Washington New Jersey
Put a new in tank pump in my deuce that worked fine for a couple of months, then stopped working. Checked the fuse on the pump itself and it's good. Is there another fuse or breaker I could check. Thanks for ant help.
Welder1
156
Albany Ga
I would check to see if you have 24V going to the pump if so you have a pump issue. you should be able to check that at the fuse holder.
