Deuce intake mushroom
Harleighguy
Placerville, California
I've seen some deuces with the intake mushroom mounted on what looks like a 90 degree elbow and raised above the hood a few inches. Is this a local mod or part of a kit? Maybe for fording or something?
hndrsonj
Senior Chief/Moderator
363
Cheyenne, WY
This Is a pic of mine, it has the fording kit so it most likely was part of it. I am pretty sure some have another piece that extends it above the hood.
That isn't part of any of the variations in the fording kits over the years. That is a field mod.
colelkhunter
any place that has semi truck parts will have this elbow. Runs about 20 bucks like listed above. They also have the extended ones if you wanted to raise it up over the hood. 90 degree bend with about 10 inches on either side.
jwaller
19
Columbia, SC
it's purpose is to help keep sideways rainwater out and snow if you get it stacked up on the fender. I bought mine years ago at napa. was about $15-20.
Wildchild467
57
Milford / Michigan
I like that 90* with the height extension. I'm going to do that, I'll post the work.:wink:
I put one on mine. The look takes getting used to, but the functionality of it is great. i was used to seeing my truck the conventional way, but now that im used to it, i like it.
The air mushroom itself could be cut down to make it look better upclose, but i did not want to do that incase i wanted to put it back to original. anyway, it will work just fine either way :)
