deuce oil filter canister large gasket numbers
nickd
36
Newport, Delaware
Its time to change the oil and the gaskets that come with the filters are not the correct size. is there a NAPA number for the proper rubber gasket at the base of the canister and the hard fiber gasket that goes under the bolt on top?
1,807
I need to get a stock of the top gasket. As far as the bottom, if you buy WIX or NAPA (WIX) they will have the bottom gasket in the kit. One day soon I hope to travel to NAPA to cross that top gasket. BTW, have you checked the crossreference section yet?
houdel
9
36
Chase, MI
I didn't have any luck finding a number for the fibre gasket. I did find a store which carries Doreman parts and fittings, they matched me up with a gasket with the right ID, OD was a little smaller but it works perfectly.
