Deuce Painted , ramps complete, Jeep in bed, Haspin or BUST
Loose Deuce
South MS.
Hope you don't have to stop suddenly, you may get a Jeep headache. That looks interesting, I would like to know more about the ramps also.
mangus580
282
Western NY
Those ramps look spooky to back up!! :freaked: WOW
Glad most times I need to put something like that in the back of mine, I have a 'loading dock' available on both ends!!
598
Karlsruhe, Germany
Hi 'ya,
first of all, greetings to all of the group, I'm new here!
@elohim1: nice rig, and an interesting ramp construction. I noticed you hooked the ramp onto the drop side; is it strong enough to support the weight of whatever crawls up there (obviously at least once ;-) ) ? Or ist this the standart procedure when using ramps ?
Cheers,
Mark
Desert Rat
Mark,
To better assist with the possibility of seeing this in person, could you please include your city and state in your signature box located in the control panel? Thanks bunches.
Trango
23
Boulder, CO
This is so excellent! This is what I'll be doing in a week, assuming I can get my junk to run. I am hooking up my radiator tonight and hopefully finishing the intake, and I have some 12" steel for ramps. Mine's a built up ZJ, but I might take the buggy (going to Moab on the 10th).
Cheers
Bob
Elohim1
Oxford, Ohio
roger-wilco-66 said:
Hi 'ya,
@elohim1: nice rig, and an interesting ramp construction. I noticed you hooked the ramp onto the drop side; is it strong enough to support the weight of whatever crawls up there (obviously at least once /DotNetForum/emoticons/wink.gif ) ? Or ist this the standart procedure when using ramps ?
Cheers,
Mark
I doubt its standard procedure, but it looks strong enough to me.
I may weld some barstock on the back of the frame butted up against ramp lip for safety. I will get some more pics and info. on the ramps tonight.
Elohim1
Oxford, Ohio
Here is a link to some close up's of the ramps and how the Jeep is tied down.
http://photobucket.com/albums/v25/elohim1/ramps/
Ramps are made with 2x4x.125 tubing. I could have used 2x3 but hindsight is 20-20. Cross supports are 1x2, this is plenty since they are basically just holding the 2x4's together. The guy who welded the ramps for me had the grating which is a overkill. I didnt see the grating before he welded it to the ramps or I would have went with somthing lighter since this is for traction purposes only.
Ramps are 11' long (to fit in bed) and 15" wide to fit between tailgate hinges.
I have about $270.00 in material and I paid someone $320.00 to weld them. I will have about $35.00 in paint to finish them.
Driving the jeep onto the truck is not bad at all. You just put the vehicle in four low and take it easy.
