Deuce pintle hitch shaft nut. Tight or loose?
JSBIRD69
19
El Paso, Colorado
I added a receiver hitch to my M35A2 a few years back, and when reassembling the pintle hitch, I tightened the main nut on the pintle shaft very tight. So tight it will not rotate under any circumstances.
Then recently, a neighbor dropped off his M35A3 for some light repairs. While doing a walk around of his truck, I noticed that his pintle hitch would rotate 360*, with little effort from this old man.
I first thought perhaps a loose hitch would allow for more travel without binding, when running cross country, but upon further reflection realized that a tight hitch wouldn't allow a trailer, such as my M105A3, to tip over sideways under any condition.
Anyone have input one way or the other? I'd like to return the A3 with as many things done properly, as possible.
TIA
Jay
fasttruck
638
Mesa, AZ
The pintle swivels and the lunette on the trailer doesn't to allow the truck and trailer to ocellate if on uneven ground they tip in opposite directions. If the pintle is rigid you will bend or break something when the trailer twists in a different direction than the truck. M 52s and 818s also allow for this as they have a double trunnion fifth wheel that will allow this oscillation if the trunnion wedges are adjusted accordingly.
M543A2
15
Warsaw, Indiana
Just tighten the nut on the pintle hook to where it does not have a lot of end play but is free to turn 360 degrees. They are to turn which is why there is a grease fitting to lubricate the pintle hook shaft as it turns on the top of the bolted on rear frame mount for the pintle hook shaft. A tight pintle will cause big problems.
rustystud
3,392
Woodinville, Washington
Many of the newer Deuces do not have grease fittings on the Pintle Hitch. I added one to mine several years ago. I posted the project.
Davidwyby
244
CA
I imagine few will take their deuce and trailer on terrain rough enough to need the pintle to swivel...but yeah.
simp5782
Feo, Fuerte y Formal
9,509
Mason, TN
It also is beneficial to swivel in the event of an accident and the trailer turns over and the truck won't go with it. It also helps with shaft wear. Itd a tapered shaft with no bearing. They do wear out
