Deuce Pump Questions
avengeusa
MI USA
I have a 71 M35, runs great, the in tank pump does pump, i can hear it spin when the switch is turned on
the problem is that it will run out of fuel after 30 gallons of fuel is burned off, about 1/4 tank on the gage
is there something on the bottom half of the pump that can fall off to make it not suck from the bottom of the tank?
mcmullag
13
Colorado Springs, CO region
pump
I think if you pull the whole assembly out, you will find that the pump height is adjustable, it is able to be tightned down at different heights along 2 or 3 ? vertical 'rails' it is mounted in. I remember seeing somebody work on this. So you should be able to loosen up some screws and slide it down deeper into the tank.
avengeusa
MI USA
aha! that may be it, i was looking for pictures, or something else to give me a clue... i seen nothing in the manual, this may be it, thanks a lot
I will pull it later and see what happens
Barrman
1,735
Giddings, Texas
Sounds like somebody pulled a pump from a tractor which has a long thinner 50 gallon tank and stuck it in your short deep 50 gallon tank.
avengeusa
MI USA
Well,
Pulled it out today, the pump was definitely not adjusted correctly, the suction part of the pump was quite a few inches too high, like about 4 inches, i looked it over, the pump adjustment bracket was also missing a bolt/nut, and the hose was swollen, i replaced the hose/clamps, adjusted the pump, added another nut/bolt and it is all good now
checked for leaks, all is well, now i just gotta drive her some more
I took a couple pics if anyone needs em
I will post em in my album
