Deuce Radiator Expansion
SasquatchSanta
Northern Minnesota
This has probably been covered but I couldn't find it in the search nor in the TMs.
I have a question about the expansion factor in the deuce radiator.
I know if you fill it to the top it will spit out a certain amount until it's reaches the required/desired level.
Does anyone know how much it is suppose to spit out "what's normal"?
What I'm finding is that when I check the radiator when it is cold the coolant is down below the inlet neck therefore unless I add coolant I can't tell if it's a quart of a gallon low.
I just did a cold check. It took just a touch over a quart before the level came up about half way in the filler neck of the radiator.
Is a quart about normal for what they will spit out???
I guess if I checked it while it was hot I would be able to see the fluid in the neck but I hate to as I don't like messing with hot radiators.
Has anyone ever built an expansion tank?
Thanks All
tm america
24
merrillville in
mine burps out to just at or below the filler neck.seems like w=everything on these trucks needs to be topped out only when completely up to opperating temp or they will spit some back out .an expansion tank would be a good idea but it would have to be a big one since there is alot of antifreeze to expand in there .you would probably need one about 1.5 gallons or so
Junglemist
Belize, Central America
I pulled my radiator about a year ago and had it cleaned and all the broken brackets brazed back on. Since then the level has stayed about half way up the elbow in the bottom of the filler neck. It has not been spitting out at all. I almost never add any fluid to it.
Jake0147
Panton, VT
Mine stays visible in the filler neck, but not much more than that. I do find that if the truck is on the slightest bit of an incline to the right (like the slope that is technically in my "flat" driveway for rainwater purposes... The coolant disappears all together.
All it is missing is the double sealed cap (I don't know if that's out there or not...) and the jug, and you could have a remote reservoir as most all modern vehicles do, and the check would be terribly easy...
