- 2,032
- 215
- 63
- North West Arkansas
Picked up my 1966 M35A2 this week in Little Rock, one of the best GL sites I have visited, always great to work with. Used the check list and only found the front differential and transmission a quart short. Added batteries and started right up. Made the 71 mile trip with only one issue, apparently one tire was low and didn't know it, by the time we made it home the valve stem had disappeared? And naturally it is an inside tire on the rear. Once we got home I found out why the front differential was low there is a pretty good leak at the top seal on the diff around the drive flange that faces the front of the truck, also how good is the power steering on a deuce should it be about as easy to turn as on a 5 ton? It has been 30 years since I drove a deuce so I have nothing to judge the easy of steering. I think my ps is weak to non exsitant on the truck right now.
Jzmes G.
Jzmes G.
