deuce rim offset problem
11Echo
96
CT W. R.
779
20
Springfield AR
Heres a question if I flipped the hubs back what is the back spacing how far from the frame? I have 9 1/2" currently and I know those 395s have less than that being 15" wide so how much backspace with stock rims is he getting?
welldigger
Benton LA
This is an interesting problem. My buddies a3 bobber with a m105a2 bed and a3 wheels has just enough offset to clear the fender wells. There's maybe 2 or 3 inches of clearance behind the tires. He is running 14.00r20 tires.
Even with the correct offset I feel you may have to tub the fenders a bit still. Probably depends on the wheels you choose. Just be prepared for the worst case.
779
20
Springfield AR
Ok guys I solved my offset problem I ll have to flip my hubs back to stock. I flipped the rim first to see what I had and WOW went from 9 1/2" to a whopping 22 1/2" so I measured the hub where the rim would rest stock 5 1/2" roughly then subtracted it from 22 1/2" and that put me at 17" then subtracted 9 1/2" I end up with 7 1/2" more back space.So no cutting needed.
4XDesign
49
Blythewood, SOUTH CAROLINA
These are my wheels. 5in backspacing I believe they came from cc Equiptment. No problems on lifted bobbed deuce with 16.00's. My bed is different but I guess what I'm getting at is these wheels move the tires out.
