Re: RE: Deuce Starter Button
As stated, that "clunk" is a
good test of the button itself. Sometimes, a simple cleaning of the battery terminals/connections will eliminate the symptoms you have. Often, just loose or corroded connections or a little oxidation can cause enough current draw and voltage drop to "miss" a start. That "inrush" that cranetruck describes is KEY!
I had a similar issue on my deuce. Turned out to be a bad crimp on the connector at the starter. I cut the old connector off and replaced it with a good crimp. I was rolling!
Make sure, (and I know you know, just a friendly reminder), to disconnect a negative battery connection before wrenching around. Cuts down on arcing, sparking, and tool welding. ------>
You probably have a simple fix. At least I hope so. For some reason, those push-button starter switches for the deuce are a little pricey, but I don't know why. I vote you stay with the push-button over the toggle
