deuce t-case
rizzo
Port Huron, MI
has anyone ever heard of a manual shift t-case for a G-742 deuce?
to my knowledge they only had the sprag type and air shift type
ida34
33
Dexter, MI
I think Memphis made a conversion kit to make a t-case manual. I am sure someone in the know will chime in but I am pretty sure it was engaged with a lever.
ida34
33
Dexter, MI
I just remembered. I think it is an REB kit. Do a search for that and see if that is what you are looking for.
rizzo
Port Huron, MI
Re: RE: deuce t-case
thanks chuck, I was searching for sprag conversion and not finding what I wanted
rizzo
Port Huron, MI
RE: Re: RE: deuce t-case
So. there were two t-cases made from the factory. a sprag and airshift. However there are chances of someone getting a sprag that was converted to a manual shift.
so right now if you were to get a deuce t-case from the junkyard it could be 1 of 3 kinds. right?
Rattlehead
Michigan
When I was shopping for a replacement t-case, one of the dealers said they had a manual shift t-case for the deuce. I can't remember which dealer though. Ended up getting a take-out airshift from a collector.
jatonka
87
Ephratah, New York
Yes there was a REB kit sold by Memphis Equipment for many years. replaced the sprag unit and another gear to give you equal gear ratio output to front and rear. I have 2 of them, not for sale but I can attest to the fact that they are great. If enough people showed any interest, I am thinking Memphis might make another production run. I remember them selling for about $475 a couple years ago. John T
rizzo
Port Huron, MI
is there a Neutral on a sprag system like the five ton? or is it either on the forward sprag or the reverse sprag. one or the other no neutral sprag position??
gringeltaube
Staff Member
2,520
Montevideo/Uruguay
Yes, you have a neutral and a very short travel btw. forward and reverse positions. There is no spring loaded detent ball on the shift mechanism, so it would be kind of tricky to adjust.
G.
