- 34,013
- 1,817
- 113
- GA Mountains
We had this before, lets get it started again. Here's the first one. If you're having problems adjusting your alt belts ie, the alt is hitting the primary filter, remove the step bracket holding the filter and place it on the bottom of the upper frame flange. It's usually on the top and this gets you an extra 1/2 of alternator swing.
