markpeltier said:
Low Range High Range Problems: The Transmission will not stay in High Range. As I drive down the road it will slip out and i haft to stop and pull the lever up to high and then i can start moveing again. Dose anyone know how to fix this problem?
Mark Peltier
Fort Gratiot, MI
Mark,
Contact Desert Rat. He had this EXACT PROBLEM while on the road. He drove from Greenvile, Kentucky to Houston, Texas in LOW GEAR (transfer case). At a WHOPPING 28 mles per hour. He has YET to live that down.
BUT he knows what happened and HOW to fix it. IS this a Sprag transfer case or an air shift transfer case? I believe DR just swapped in an air shift in place of his Sprag. So, contact Brent (DR) and he will be happy to help.
He just returned from Howard Hammonds again (Greenville, Ky) for the second time this summer. Uneventful and only took two days.
hope that helps
jim
