Deuce Turn Signal/Hazard light Switch????
saddamsnightmare
80
Abilene, Texas
August 9th, 2008.
Learned Seers of the Duece:
Just a minor question about the D.C.Electronics, Aurora, Ill turn signal unit No. PN:M620691/1-2-11613632? This is the one with a serrated end lower lever underneath the main turn signal lever.... My 1971 Kaiser Jeep M35A2 has turn signals, but no hazard lights... does the lower lever, which seems to be able to slide in (towards the wheel) and out serve as a hazard light switch? It seems odd that a 1971 M35A2 rebuilt for Desert Storm in 1990, has made it all these years without a hazard light circuit of any type, where our construction dumptrucks built at the same time had hazard light switches....?
When pushed in or out, this auxilliary lever seems to do nothing at all, it doesn't latch or unlatch, it doesn't work the turn signals as hazards, it seems odd that they would bother to put this item on the main turn signal lever if it does nothing???? I know photos will be wanted, but I haven't got the hang of a digital camera, and a regular one seems not to be useful in the circumstance. However, I am certain that more then one of you out there have dueces with this set up, and may be able to shed some significant light on this question..... [thumbzup]
Thanks Again,
Sincerely,
Kyle F. McGrogan
1971 Kaiser Jeep M35A2 Wo/W "Saddam's Nightmare" Desert Storm and Vietnam Veteran Deuce
1968 Johnson Corp M105A2 Cargo Trailer
1967 Hercules MEP023A Gas Gen-Set APU
1963 Swiss Army Cargo Unimog, S.404.114 MB
dabtl
Denton, Texas
Push the turn signal to the right turn position. Pull the serrated lever out and push the turn signal lever up another click at the same time to the hazard position.
