If the price is right see if you can get the seller to measure the bolt pattern for you. I assume you want to go w/bigger tires? The width would be good to know as well. Are they 2 pc rims or will you need to have them mounted and balanced? The A3 rims are pretty good. You may want to search the multitude of wheel debates here. Then you need to find out what the offset will be. Some guys are comfortable flipping the hubs, some are against it. I am putting my 395's on stock rims for now w/tubes and flaps. I will go w/converted Hemmit rims or A3's next spring. I just like the idea of a 2pc rim vs split ring. I have been told by people I trust, that the stock rims work fine.
