Deuce winch issue
Jim Hunter
Hello guys,
I am trying to remove the LH case from my winch but no luck...
I read the TM 9-2320-209-34-2-3 and there is nothing special to remove the case.
In the winch the drag brake handle was bent and is almost touching the upper cover...Also it moves a little...
Any ideas ?
Thank you,
jim
gringeltaube
Staff Member
2,640
Montevideo/Uruguay
LH......? You mean the gear case on the driver's side, or the clutch housing, on the pass. side (= your left when standing in front of the truck and reading the dataplates)...?
Drag brake handle, what is that? There is a small handle, for the drum lock and a lever for the clutch (which could be bent like you describe); on the clutch housing side.
I suspect that it was that end you wanted to remove, so see diagram below: in order to come off with no effort, clutch #37 must slide freely on shaft #33 and keys #32. If not, then rust may be the cause.
Remove fill and drain plugs and take a look inside using a small flashlight.
G.
Jim Hunter
Finally I return the winch to the yard and take another that is never used !
Altough inside the brake housing was full of black sludge!
I am trying to find out the way to remove the brake cylinder as TM say just remove it without any information !!!
Rgds,
Jim
gringeltaube
Staff Member
2,640
Montevideo/Uruguay
........I am trying to find out the way to remove the brake cylinder .....................
You mean pulling that rusty brake drum off the (rusty)shaft end(?):wink:
Now, if I read well your signature...that shouldn't be a problem at all; so I was waiting for your "found the way!" post... :p
It is not a press fit, just rust that keeps it stuck on.
Here some old tricks (in case it didn't fall off yet): plenty of oil; heat/cool, repeatedly; carefully hit it while pulling out (hook through 1 of 4 windows) or use a pull hammer; or fabricate a simple screw puller, using two 12mm bolts with heads trimmed to act as hooks.
Patience; it will come off!:)
G.
Jim Hunter
Thanks for the nice tips but this one is really fixed to the shaft !
Usually a little heat and some Kroil do the trick but this one is really tight...
I also use my chain inside the 4 windows to pull it out but no luck also...
