I have a similar issue that I've had since getting the truck. It fires right up and either idles real low (vibrating like crazy) or dies. I also notice a significant variance in drivability - sometimes it runs great with extra power and sometimes it's gutless. I slow a bit on light grades and get down to 40MPH or so on heavy grades, like I-5 N at Capital\Barbor area (long, heavy grade). It idles fine after a minute or so of ~900RPM idle using the hand throttle. It also seems like it runs better when very warm or just after a fillup if it was ran earlier in the day. It seems like it doesn't have the idle problem as bad if I run the lift pump for a few minutes beforre starting it up (may be my imagination). I've posted on here in other threads and get the same feedback. My setup:
LDT-465 with C turbo that was rebuilt ~93, ~1600 hours
JATonka filters all around that have been replaced (the fuel was clean beforehand)
POP tested my injectors (all OK, it's on youtube)
Running #2 with ~15% bio, it's all you can find in the Portland area (that I know of)
Added peashooter gage box with pyro with thermocouple pre-turbo and boost gage (I get up to 7psi boost at high RPM when it runs good, 4psi or less when it runs bad)
Little to no smoke unless I goose it at idle
Just installed 365/80R20's after flipping hubs and rebuilding the rear axles (new seals, cleaned brakes and all that). It seems to go down the road a bit easier now
The weather has been crappy here lately, so I haven't been able to do much. Hopefull in the next couple days I'll bypass the FDC and see what happens. I also ordered new semi-translucent lines so I can try to look in and see if there are air bubbles getting fed around. My original lines are caked with green paint like I suspect most of them are.
I'm having an issue with the idle on my a2 after I put some oil in the fuel. I spent a good deal getting a centrifuge cleaning system set up and for my first test ran about 15 gallons of oil through it, passed that through a 10 micron filter/water separator and mixed it in the tank with about 15 gallons of diesel. I immediately noticed something was wrong as it was not wanting to idle cold. It would start fine and die in a matter or 5 seconds. I could pull the hand throttle and it would run at 1000 rpm and after driving it around a while it would idle fine once the engine was warmed up. I thought it could be the fuel filters so I replaced all of them and that didn't help. I took it on a trip and it seemed to run and drive just fine. It idled just fine before I put any oil in the tank and now I'm at a loss.
the FDC is still hooked up and besides jatonka oil filters I have done no other mods to the engine. the engine is a ltd-1D and has ~9k miles
Any Ideas?
