ferb444
- 0
- 0
- Johnstown, PA
I have had my 1968 M35A2 for about 2 years. roughly 30000 miles, and around 900 hours on the gauges. Recently i packed about 2 ton of rocks in the bed and took them to a friends house....never made it. The truck will move, but you really have to step on the throttle to get it going. never did this before. very similar to this users post, that i read, http://www.steelsoldiers.com/cucv/6...ck-power-black-smoke-higher-rpm-sluggish.html his solution was an oil change.... don't believe it... but his description is sluggish, i stopped driving and let it sit for 2 days, then the land owner told me to move it. so i did, made it about 5 miles and now the truck will not move any further. Give it throttle, won't go, 1st gear, reverse, high, low. won't move. seams like the drive shaft won't spin either, front axel or rear axel engaged. i can't tell cause i'm in the truck.... it smelled a little when driving but i figured it was just the massive throttle i gave it. The Brakes aren't stuck, but the smell seems to be maybe the clutch. i can put it in gear and let the clutch all the way out and it seems like it won't catch...any ideas or solutions would be great! thanks guys.
