Deuce wont start without ether
sprockett2103
United Kindom
Hi all.
hopefully someone will help...
had my M35 for 18 months, always started and ran well, no problems.
renewed the filters just after i got it, i did use some WVO about a year ago, but recently have been running a 50/50 mix of diesel and kerosene, still it ran fine.
truck has sat all winter, with the occasional start and warm up, still no problems.
last weekend stopped at the local garage and put 10 gal diesel in, started up, left the garage no prob, approx 10 miles later, rolled up to a junction, engine died, would not start.
drained the primary filter at the side of the road, and quite a bit of water and white sludge came out, then drained the sec and final, more sludgy stuff. refilled and bled, still no start.
Cracked an injector line, and was getting some, but not lots of diesel.
so as a last resort, and i hate using it, gave a puff of ether... and it started straight up, wont idle under 1000rpm.
since then, drove it gently home, drained the tank and binned the fuel, steamed in the tank cleaned pump strainer, blown all the lines through with compressed air, new filters, new fuel. still wont start, only with ether.
ive had the stop valve out an it had a brown residue on it, but it wasnt stuck. cleaned and put back in, still the same.
the plunger is going up and down in the HH. my last resort is going to be park it up the road and set it alight.....
any suggestions very greatfully received.
hopefully not needing parts as in the UK parts are very expensive.
thanks in advance.
mark
RAYZER
58
sanford/florida
Don't set it on fire yet!
Sounds to me like a sticky fuel control govener rod, pull the side cover on the i p (directly under the head) and check, you can run the engine when cover is off.
Also check the peddle for sticking, pull up on it while the engine is running and see if it brings the idle down.
Good luck.
Carlo
20
palazzago italia
Good luck.
I had this same problem. There was rust on the rod causing it to stick. Good call.
RAYZER
58
sanford/florida
Did you replace all fuel filters or just drain them?
They may be clogged.
Edit: I see where you said filters were replaced, a fuel system air leak would cause hard starting, i have seen where turning the fuel up a little solves a hard start low idle issue.
RAYZER
58
sanford/florida
That should be one of the first things to ck. I've never had one go bad but with out it running 100% it might make these problems.
I agree, and check for fuel pressure out of it, I had one where the pump foot came apart in the tank, i could hear it runnng but no pressure.
Warthog
229
OKC, OK
The fuel control rod actually controls the amount of fuel that the injector pump sends to the injectors. If it is gummed up it will not allow the fuel to flow correctly. Sometimes they stick shut, sometimes wide open and sometimes just gummed to where it won't idle below 1000 rpm.
Your description of the fuel stop leads me to the gummed up problem.
The low pressure fuel is the grey shading, it flows down to area of the spill passage. When you use the foot throttle it will move the fuel control unit which in turn moves the plunger sleeve. The more the plunger sleeve uncovers the spill passage the more fuel will be allowed in the spill passage and then on to the injectors. If any of this is gummed up (your brown residue description) it will affect the fuel flow.
sprockett2103
United Kindom
had the pump out and cleaned it up,tried it in a bucket of clean diesel, sprayed about 10 feet, assume that means its working, is there anywhere i can put in a pressure gauge?
Warthog
229
OKC, OK
You can put a pressure gauge in the port for the bleeder valve on the secondary filter.
Floridianson
2,491
Interlachen Fl.
Warthog [ATTACH=CONFIG said:
491948[/ATTACH]View attachment 491949
Just to keep things straight do believe when the spill port is open it can't build pressure so spill port open no fuel pressure it shuts off. Not when it it open it lets more fuel in. It is the spill port not the fill port.
Floridianson
2,491
Interlachen Fl.
Also by placing the test gage on the final fuel filters you can check intank pump of course but then when the engine is running you can check the IP lift pump pressures. You won't be able to check the IP pump with the gage on the fuel tank. I also do not leave gages on the truck I only hook them up to check a problem.
rustystud
2,760
Woodinville, Washington
View attachment 491948View attachment 491949
Warthog, what manual is that diagram from ? Thanks.
EDIT : I just looked at Floridianson's pictures and see that it's from TM 9-2910-226-34 .
sprockett2103
United Kindom
i think some crap might have made it through to the HH, is it possible to dismantle it and clean it once its removed, dont want to mess it up, parts are hard to come by in the UK
