paccrest
- 0
- 0
- Medford, OR
I have a turbocharged multifuel engine in my 1963 Duece. The oil volume continues to rise with more hours on the truck. I just changed the oil and about every 400-500 miles it shows that is is about 2 quarts high. I drained it off and it continues to rise. The oil does not smell particularly like diesel but it is definitely not water as the oil is black not milky at all. I am assuming that it is diesel leaking in from somewhere. I am not a mechanic but from what I can gather the only place oil and diesel are in the same area would be at the injection pump. Maybe a bad seal? Not sure. Any thoughts of what this could be so I can get the parts and remedy the problem as soon as possible would be very helpful. I would be especially interested in comments from someone that had the same problem. If not though, any help would be appreciated. Thanks.
Bret
Bret
