Difference between M101's and M105's?
Strategic Tactical
Ogden Utah
ok, Newby here. What is the difference between the two trailers? I'm just guessing that the difference is weight that can be loaded in it? I'm looking for one to pull behind my M35A2 and want the correct one.
CycleJay
Marietta, Ga
Than go with the M105..
Unless I am wrong, that should be the correct trailer for it.
I have seen quite a few M105's behind M35A2's.
Just my 2cents
Barrman
1,712
Giddings, Texas
As stated above, the 105 is the proper trailer for the M35. It has an empty weight of 2700 pounds, has the same rims and tires as the M35 and has air brakes that hook up to the M35. They are great behind a M35 and honestly, too big for even a modern 1 ton civilian truck.
The M101 has an empty weight of 1270 I think, has either M37 or CUCV rims/tires depending on the year and has either no brakes or surge brakes. Again, depending on the year. They will fit behind a M35, but you can't see it, ever in the mirrors. They are perfect behind a modern full size SUV or pick up though.
665
Madison Alabama
M101
147 inches
Length, cargo box 76 inches
Width, overall 73.5 inches
Width, cargo box 65.5 inches
Height 35 inches
Height w/cover 83 inches
Ground clearance 14 inches
Weight 1,340 lbs
Capacity 1,500 lbs (M101A3: 2,000 lbs)
Note: Dimenstions are for the M101A2 variant.
M105
Net weight 2,650 lbs
Max gross wt 7,150 lbs
Total length 165.5 in
Cargo body length 110 in
Total width 83 in
Cargo body width 74 in
Cargo deck height above ground 37 in
Cargo load height under bows 60 in
Cargo load height to top of side racks 45 in
Cargo load height to top of side panels 18 in
Like already stated you want the M105.
