Thanks for the info - I hit the wrong key and meant to compare the 931A2 to M931A1 - but I get the general differences now. Main reason was that I was curious why the A2 seems to be more sought after. Must be the CTIS - I didn't thing the nhc250 was a bad motor?????m932a2 = CTIS , 8.3 cummins ,winch m931a1 = no CTIS , nhc250, no winch
Here in Illinois you can't get a collector plate for a truck over 8000 Lbs. You can register it as a RV if the proper mods are done, otherwise a commercial plate/CDL is required.I don't know about other states, but, in Maryland, the vehicles need to be 20 years old for collector plates.
Update: Illinois now has FMV plate- $100/yr for light (under 26K) trucks and $150/yr for the big boys over 26K . Probably the only good results out of Springfield.Here in Illinois you can't get a collector plate for a truck over 8000 Lbs. You can register it as a RV if the proper mods are done, otherwise a commercial plate/CDL is required.
