Difference between M998 and M998A1 & Engines
erasedhammer
58
Maryland
So I cannot find anywhere what the difference is between an M998 and the A1 version. I notice the weight of the vehicle was increased by 180 lbs. So what did they add?
Also, I saw that 1982-1993 humvees and hummers used the 6.2 NA, and 1994-2004 that its all 6.5 NA's and Turbos. So my vehicle is a 1994, but it was advertised on govplanet as a 6.2. Did they still put 6.2s in 94 humvees or is that a mistake? Where are the markings on the engine to determine the engine displacement?
Joehop
Milton, Delaware
To determine if you have a 6.2 or 6.5 you need to remove the inside engine cover and look at the oil sending unit, If the hold down flange is on the left then its a 6.2, if its on the right then its a 6.5
Lionel
24
Baltimore/ MD
From AM General's site;
"A1 advances incorporated across the new production fleet included: new front seats, improved parking brake lever with safety release, metal hood grille, improved slave receptacle, solid state glow plug controller, modified rifle mounts and upgraded rear half shafts."
I know my '94 A1 also has the brake upgrade that incorporates the parking brake into the rear calipers, eliminating the propeller shaft disk brake. But this was apparently done at the "reset" for any 998.
juanprado
2,829
Metairie/La (N'awlins)
Just curious as to what was different with the slave receptacle and what was different with the rifle holders as I have only seen one style of each and was not aware of any differences?
Action
1,555
East Tennessee
Humvees were not inproduction in 1982, and 2004 was not the last year.
As far as you driving a 1994 with a 6.2. That is entirely possible, because it could be a new data plate with the wrong year, as many of the GP Humvees have.
erasedhammer
58
Maryland
I got that information from wikipedia, so it could be wrong. It had two dates 1994 to 2004 and 1994 to present.
Is there any way to tell the age of the vehicle if the data plate is wrong? Currently I am unable to register the vehicle at its current age, but if it was 3 years older I could register it as an antique vehicle.
Lionel
24
Baltimore/ MD
"and 1994-2004 that its all 6.5 NA's and Turbos"
From what I have determined, Turbo's did not come off the production line until 1996 and after.
Action
1,555
East Tennessee
You have to use what is on the data plate. It isn't supposed to be on the road, anyways.
The serial number would help to get a year of production, but I haven't seen a list of cut-off numbers. There is a post on this site where the guy will get you info from your VIN.
Lionel
24
Baltimore/ MD
A link to your truck so we can take a look may help.
alpine44
Asheville, NC - Elkton, MD
There is an easier way to tell whether the vehicle has a 6.2L or 6.5L engine. Look at the coolant crossover and compare the connection to water pump.
brazengoat06
Tulsa, OK
just bought my first M998A1 from GP. I did notice that its advertised as a 95 but has a 6.2 with 1990 on the emissions exemption label. Not sure what thats about. Thought maybe they just swapped motors from a 90 model.
desmodromic
22
New York, New York
I have a 1995 A1 with a 6.2 also. My assumption was that AM General stuffed a left over 6.2 in there, but it is just as likely the motor pool did it at some point. It has all LED lights and the 210 amp alternator FWIW.
